Ir para o conteúdo principal
How to Clean a Flat Iron
O que você precisa
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: passo 1, imagem 1 %32
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: passo 2, imagem 1 %32 How to Clean a Flat Iron: passo 2, imagem 2 %32
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: passo 3, imagem 1 %32 How to Clean a Flat Iron: passo 3, imagem 2 %32
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: passo 5, imagem 1 %32 How to Clean a Flat Iron: passo 5, imagem 2 %32
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: passo 6, imagem 1 %32 How to Clean a Flat Iron: passo 6, imagem 2 %32
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: passo 7, imagem 1 %32
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: passo 8, imagem 1 %32
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: passo 9, imagem 1 %32
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
Conclusão
Congratulations your flat iron is buildup free!
3 outras pessoas executaram este guia.
Jacquelin
Membro desde: 02/23/15
283 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-2, Green Winter 2015 Membro de Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
Membros da 6
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 46
Duração total: 5,768
