Ir para o conteúdo principal
How to Clean a Filter on a MAYTAG Laundry Machine
O que você precisa
  1. How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: passo 1, imagem 1 %32 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: passo 1, imagem 2 %32 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: passo 1, imagem 3 %32
    • Remove the screws (3) underneath the washing machine using the socket wrench, the extension rod, and the converter.
  2. How to Clean a Filter on a MAYTAG Laundry Machine: passo 2, imagem 1 %32 How to Clean a Filter on a MAYTAG Laundry Machine: passo 2, imagem 2 %32 How to Clean a Filter on a MAYTAG Laundry Machine: passo 2, imagem 3 %32
    • Put a tray/rags underneath the washing machine in case water leaks out.
    • Remove the bottom lid of the washing machine.
  3. How to Clean a Filter on a MAYTAG Laundry Machine: passo 3, imagem 1 %32
    • Turn the filter counterclockwise until you can pull out the filter.
  4. How to Clean a Filter on a MAYTAG Laundry Machine: passo 4, imagem 1 %32 How to Clean a Filter on a MAYTAG Laundry Machine: passo 4, imagem 2 %32 How to Clean a Filter on a MAYTAG Laundry Machine: passo 4, imagem 3 %32
    • Scrub/wash the filter of debris.
  5. How to Clean a Filter on a MAYTAG Laundry Machine: passo 5, imagem 1 %32
    • Screw the filter clockwise back into place.
Linha de Chegada
Kaelyn Taing
Membro desde: 10/26/22
121 Reputação
Autoria de 1 guia
Equipe
Um comentário
A tricky part of this maintenance task is removing and replacing the front cover behind which the filter resides. This guide is inadequate for that part of the job.
Carlo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 17
Últimos 7 dias: 87
Últimos 30 dias: 453
Duração total: 7,286
