Ir para o conteúdo principal
How to Clean a Dirt Devil Vacuum Cleaner Roller Brush
O que você precisa
  1. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush, How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 1, imagem 1 %32
    • Lay the vacuum cleaner on the floor so that the bottom of the vacuum is facing upwards.
  2. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 2, imagem 1 %32
    • Use a Phillips head screwdriver to remove eight screws.
  3. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 3, imagem 1 %32
    • Disassemble the vacuum head and pop out your roller brush.
  4. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 4, imagem 1 %32
    • Cut the ends with scissors.
    • Cover the floor with papers to prevent debris and hair from falling on the ground.
  5. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 5, imagem 1 %32
    • Use a brush to clean the roller brush.
  6. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 6, imagem 1 %32 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 6, imagem 2 %32
    • Put the rectangular part on both sides.
  7. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 7, imagem 1 %32 How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 7, imagem 2 %32
    • Check if the belt is attached.
    • Check if the motor part is well inserted with the belt attached to the roller brush.
    • Make sure the shape of the motor fits to prevent it from falling.
  8. How to Clean a Dirt Devil Vacuum Cleaner Roller Brush: passo 8, imagem 1 %32
    • Use your Phillips head screwdriver to screw in all eight of the screws.
Linha de Chegada
Uma outra pessoa concluiu este guia.
4 comentários
Might be helpful if you showed where all 8 screws are seeing how I can only find 6 and cannot get it open!
Crystal - Responder
in the front there are to wheels, pop them out and you will see the other 2 screws
Mario Lore -
my power express lite only has 6 screws as well. I cannot get it open, I'm afraid it will break if I keep prying.
Gregory Penniston - Responder
Can I hand wash the brushes and rollers.
Lynne - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 52
Últimos 30 dias: 238
Duração total: 7,782
