Ir para o conteúdo principal
How to Clean SteelSeries Apex Pro Gaming Keyboard
O que você precisa
  1. How to Clean SteelSeries Apex Pro Gaming Keyboard, How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 1, imagem 1 %32
    • Place the keyboard down on a flat surface and disconnect from any power source.
  2. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 2, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 2, imagem 2 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 2, imagem 3 %32
    • Pour some isopropyl alcohol into a paper towel.
    • Use the same paper towel to clean the keyboard and the keyboard rest pad.
  3. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 3, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 3, imagem 2 %32
    • Use your index finger and thumb to remove each key cap starting from left to right.
    • Remove the smaller key caps first so the surrounding larger key caps can be removed easier.
    • Place each key cap that was removed from the keyboard on a flat surface in order from left to right.
  4. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 4, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 4, imagem 2 %32
    • Use a can of compressed air to remove all the dust from the keyboard.
  5. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 5, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 5, imagem 2 %32
    • Dip a cotton swab into the isopropyl alcohol bottle.
    • Use the cotton swab to clean tight spots on the keyboard.
  6. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 6, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 6, imagem 2 %32
    • Dip another cotton swab in the isopropyl alcohol.
    • Use the cotton swab to clean the inside and outside of every key switch.
  7. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 7, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 7, imagem 2 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 7, imagem 3 %32
    • Use your index finger and thumb to place the keycaps on the keyboard, starting from the top to the bottom.
  8. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 8, imagem 1 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 8, imagem 2 %32 How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 8, imagem 3 %32
    • Use the paper towel to clean the keyboard, keyboard rest bar, and the keyboard's cable.
  9. How to Clean SteelSeries Apex Pro Gaming Keyboard: passo 9, imagem 1 %32
    • Make sure all keycaps are placed in the right place and functioning properly.
Conclusão
Congratulations, your SteelSeries Apex Pro keyboard is clean! Repeat these steps every once in a while as needed to keep your keyboard clean and extend the life of your keyboard.
Luis Espinosa
Membro desde: 01/24/22
169 Reputação
Autoria de 1 guia
Equipe
2Comentários do guia
Je pense qu'utiliser de l'acool isopropylique est une c...erie
Guynemer - Responder
Pourquoi ? Argumentes.
Parce que ça désinfecte, nettoie en profondeur les touches sans risque de voir les caractères s'effacer ? (sauf clavier leader price bien sûr)
Valurion -
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 99
Ao todo: 8,118
