Ir para o conteúdo principal
How to Clean Mesh Shoes
O que você precisa
  1. How to Clean Mesh Shoes, Prepare for cleaning: passo 1, imagem 1 %32 How to Clean Mesh Shoes, Prepare for cleaning: passo 1, imagem 2 %32 How to Clean Mesh Shoes, Prepare for cleaning: passo 1, imagem 3 %32
    • Identify the type of dirt that the shoe is covered with.
    • Note: different types of dirt may require different cleaning approaches, in this example the shoe had soil and dust.
    • Gather all the tools needed for the repair.
    Pergunte ao FixBot
    Comentar
  2. How to Clean Mesh Shoes, Brush off any dirt: passo 2, imagem 1 %32
    • Using a dry soft brush to gently remove dirt and debris from the surface.
    Pergunte ao FixBot
    Comentar
  3. How to Clean Mesh Shoes, Remove the laces and insert a shoe model or paper: passo 3, imagem 1 %32 How to Clean Mesh Shoes, Remove the laces and insert a shoe model or paper: passo 3, imagem 2 %32 How to Clean Mesh Shoes, Remove the laces and insert a shoe model or paper: passo 3, imagem 3 %32
    • Take off the laces from your shoes to ensure a thorough clean.
    • Place a shoe model or crumpled paper inside each shoe to help maintain their shape during cleaning.
    Pergunte ao FixBot
    Comentar
  4. How to Clean Mesh Shoes, Prepare the Cleaning Solution: passo 4, imagem 1 %32 How to Clean Mesh Shoes, Prepare the Cleaning Solution: passo 4, imagem 2 %32 How to Clean Mesh Shoes, Prepare the Cleaning Solution: passo 4, imagem 3 %32
    • In a separate bowl, mix a small spoonful of baking soda with an equal amount of laundry detergent and twice the amount of water. Stir the mixture to create a paste.
    • Tip: adjust the quantity based on how dirty your shoes are.
    Pergunte ao FixBot
    Comentar
  5. How to Clean Mesh Shoes, Clean with the Brush: passo 5, imagem 1 %32 How to Clean Mesh Shoes, Clean with the Brush: passo 5, imagem 2 %32
    • Dip the brush into the mixture and gently scrub the mesh surfaces of the shoes.
    Pergunte ao FixBot
    Comentar
  6. How to Clean Mesh Shoes, Dry and Replace Laces: passo 6, imagem 1 %32 How to Clean Mesh Shoes, Dry and Replace Laces: passo 6, imagem 2 %32
    • Use a clean, dry cloth to wipe away any excess moisture and residue from the shoes.
    • Allow them to air dry completely and relace the sneaker.
    Pergunte ao FixBot
    Comentar
  7. How to Clean Mesh Shoes, Finished and Ready!: passo 7, imagem 1 %32 How to Clean Mesh Shoes, Finished and Ready!: passo 7, imagem 2 %32
    • 🛠️🏆👏 Congratulations! The cleaning is complete, and you're ready to go!
    Pergunte ao FixBot
    Comentar
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro desde: 07/19/23
10.230 Reputação
Autoria de 68 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
25 Membros
Autoria de 172 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 40
Ao todo: 295
