Ir para o conteúdo principal
How to Clean Corroded Battery Terminals
O que você precisa
  1. How to Clean Corroded Battery Terminals, Safety precautions: passo 1, imagem 1 %32
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
  2. How to Clean Corroded Battery Terminals, Remove the batteries: passo 2, imagem 1 %32 How to Clean Corroded Battery Terminals, Remove the batteries: passo 2, imagem 2 %32 How to Clean Corroded Battery Terminals, Remove the batteries: passo 2, imagem 3 %32
    • Remove the batteries from your device.
    • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
    • If any batteries are stuck, follow the next step as normal to clean around them.
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: passo 3, imagem 1 %32 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: passo 3, imagem 2 %32 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Anti-Static Brush
    $2.99
    • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: passo 4, imagem 1 %32 How to Clean Corroded Battery Terminals, Remove any stuck batteries: passo 4, imagem 2 %32
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
  5. How to Clean Corroded Battery Terminals, Clean the terminals: passo 5, imagem 1 %32 How to Clean Corroded Battery Terminals, Clean the terminals: passo 5, imagem 2 %32 How to Clean Corroded Battery Terminals, Clean the terminals: passo 5, imagem 3 %32
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
  6. How to Clean Corroded Battery Terminals: passo 6, imagem 1 %32 How to Clean Corroded Battery Terminals: passo 6, imagem 2 %32 How to Clean Corroded Battery Terminals: passo 6, imagem 3 %32
    Microfiber Cleaning Cloths
    $3.99
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
  7. How to Clean Corroded Battery Terminals, Install new batteries: passo 7, imagem 1 %32 How to Clean Corroded Battery Terminals, Install new batteries: passo 7, imagem 2 %32 How to Clean Corroded Battery Terminals, Install new batteries: passo 7, imagem 3 %32
Conclusão
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
9 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
150.284 Reputação
Autoria de 995 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.649 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 119
Últimos 7 dias: 823
Últimos 30 dias: 4,402
Ao todo: 49,330
