Ir para o conteúdo principal
How to Check a Car's Tire Pressure
O que você precisa
    1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: passo 1, imagem 1 %32 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: passo 1, imagem 2 %32
      • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
      • You can also look up this information in your vehicle's owner's manual.
      • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
      Pergunte ao FixBot
      Comentar
    2. How to Check a Car's Tire Pressure: passo 2, imagem 1 %32 How to Check a Car's Tire Pressure: passo 2, imagem 2 %32 How to Check a Car's Tire Pressure: passo 2, imagem 3 %32
      • Each tire has a valve stem located on the outer part of the wheel that sticks out.
      • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
      • The cap is very small, so be sure to keep track of it!
      Pergunte ao FixBot
      Comentar
    3. How to Check a Car's Tire Pressure: passo 3, imagem 1 %32 How to Check a Car's Tire Pressure: passo 3, imagem 2 %32
      • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
      • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
      • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
      Pergunte ao FixBot
      Comentar
    4. How to Check a Car's Tire Pressure: passo 4, imagem 1 %32 How to Check a Car's Tire Pressure: passo 4, imagem 2 %32
      • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
      • To reset the gauge to zero, press down on the gauge's bleeder valve.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
4 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
43.097 Reputação
Autoria de 82 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 24
Últimos 7 dias: 233
Últimos 30 dias: 640
Ao todo: 4,739
