Ir para o conteúdo principal
How to Check Your iPhone's Battery Health
  1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: passo 1, imagem 1 %32
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. How to Check Your iPhone's Battery Health: passo 2, imagem 1 %32
    • Scroll down and select Battery.
  3. How to Check Your iPhone's Battery Health: passo 3, imagem 1 %32
    • Select Battery Health.
  4. How to Check Your iPhone's Battery Health: passo 4, imagem 1 %32
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Over many charge and discharge cycles, this number will gradually drop.
    • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
  5. How to Check Your iPhone's Battery Health: passo 5, imagem 1 %32 How to Check Your iPhone's Battery Health: passo 5, imagem 2 %32 How to Check Your iPhone's Battery Health: passo 5, imagem 3 %32
    • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
    • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
    • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
Conclusão
That's all folks!
29 outras pessoas executaram este guia.
Josh M
Membro desde: 11/24/14
931 Reputação
Autoria de 1 guia
Equipe
iTech West Palm Beach Membro de iTech West Palm Beach
Business
5 Membros
Autoria de 7 guias
4Comentários do guia
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - Responder Compartilhar
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - Responder Compartilhar
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M - Compartilhar
mine iphone 6 cannot watch battery health
gfght - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 44
Últimos 30 dias: 169
Ao todo: 14,396
