Ir para o conteúdo principal
How to Charge a Drained 2009 Toyota Prius Battery
O que você precisa
  1. How to Charge a Drained 2009 Toyota Prius Battery, How to Charge a Drained 2009 Toyota Prius Battery: passo 1, imagem 1 %32
    • First of all, you will need some kind of battery charger. It can be any type of battery charger with a positive and negative lead (Red and Black grips).
    • You may also need an extension cord in order to connect the battery charger to a nearby power outlet.
  2. How to Charge a Drained 2009 Toyota Prius Battery: passo 2, imagem 1 %32
    • Before beginning the procedure, make sure all your lights are off.
    • Unlatch your hood by pulling on this level, located underneath the steering wheel.
  3. How to Charge a Drained 2009 Toyota Prius Battery: passo 3, imagem 1 %32
    • Reach under the hood and find the lever that releases the hood. push up on it and lift the hood.
  4. How to Charge a Drained 2009 Toyota Prius Battery: passo 4, imagem 1 %32 How to Charge a Drained 2009 Toyota Prius Battery: passo 4, imagem 2 %32
    • Unlatch the metal rod and place it in the designed area so it will hold up the hood.
  5. How to Charge a Drained 2009 Toyota Prius Battery: passo 5, imagem 1 %32 How to Charge a Drained 2009 Toyota Prius Battery: passo 5, imagem 2 %32
    • Remove the cover off the fuse box by pressing the 2 tabs on the bottom and left side of the box
    • The second tab is located on the lowest part of the fuse box, and can be rather hard to see. The orange arrow points to where the tab is located.
  6. How to Charge a Drained 2009 Toyota Prius Battery: passo 6, imagem 1 %32 How to Charge a Drained 2009 Toyota Prius Battery: passo 6, imagem 2 %32
    • Flip open the plastic red cover with a plus sign on it.
    • This is the positive terminal, and this is where the red lead is going to attach to.
  7. How to Charge a Drained 2009 Toyota Prius Battery: passo 7, imagem 1 %32
    • Attach the positive RED lead to the positive terminal
    • If there is a small spark, it is okay, there is nothing wrong with that.
    • DO NOT let the red and black leads touch each other. This may cause an electric shock.
  8. How to Charge a Drained 2009 Toyota Prius Battery: passo 8, imagem 1 %32 How to Charge a Drained 2009 Toyota Prius Battery: passo 8, imagem 2 %32
    • Attach the negative (black lead) to some metal surface, preferably a large bolt.
    • Once again, if there is a small spark, it is completely okay.
  9. How to Charge a Drained 2009 Toyota Prius Battery: passo 9, imagem 1 %32
    • Once your leads are connected, you can lower the hood (Don't slam it down) so that the cables do not get damaged.
    • Leave your car to charge for at least 3 hours, or even overnight! keep in mind that if you only charge it for 2 or 3 hours, you will need to drive it around (or just leave the engine running) for another hour so that the engine will finish the charge.
Conclusão
Once the charge is complete, follow the instructions backwards to put everything back into place.
2 comentários
VERY clear instructions on charging my wife’s 2009 Prius. Not rocket science, BUT I didn’t know where the terminals were, or if there were any special precautions with a hybrid. Thanks!
Tom Henrich - Responder
Terrific info…..
Last time I charge my 09 battery. I had to take it out of the back..A Big pain in the Butt “it was”
I thank U for your info and my back thanks U..!
DALE
Dale Myers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 24
Últimos 30 dias: 114
Duração total: 8,391
