Ir para o conteúdo principal
How to Change Mortise Lock and its Cylinder
O que você precisa
  1. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: passo 1, imagem 1 %32 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: passo 1, imagem 2 %32 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: passo 1, imagem 3 %32
    • Determine the position of the screws on both door handles and the front plate.
  2. How to Change Mortise Lock and its Cylinder: passo 2, imagem 1 %32 How to Change Mortise Lock and its Cylinder: passo 2, imagem 2 %32
    • Use a flathead screwdriver to remove the eight 6 mm screws on both handles.
  3. How to Change Mortise Lock and its Cylinder: passo 3, imagem 1 %32 How to Change Mortise Lock and its Cylinder: passo 3, imagem 2 %32 How to Change Mortise Lock and its Cylinder: passo 3, imagem 3 %32
    • Pull out the door handles on both sides of the door.
  4. How to Change Mortise Lock and its Cylinder: passo 4, imagem 1 %32 How to Change Mortise Lock and its Cylinder: passo 4, imagem 2 %32 How to Change Mortise Lock and its Cylinder: passo 4, imagem 3 %32
    • Pull out the spindle (the rectangular piece of metal) from the door.
  5. How to Change Mortise Lock and its Cylinder: passo 5, imagem 1 %32 How to Change Mortise Lock and its Cylinder: passo 5, imagem 2 %32 How to Change Mortise Lock and its Cylinder: passo 5, imagem 3 %32
    • Loosen the two 6 mm flathead screws at the top and bottom of the lock using a flathead screwdriver.
    • Remove the third 6 mm Phillips screw in the middle using a Phillips #1 screwdriver.
  6. How to Change Mortise Lock and its Cylinder: passo 6, imagem 1 %32 How to Change Mortise Lock and its Cylinder: passo 6, imagem 2 %32
    • Pull the lock cylinder out to either side of the door.
  7. How to Change Mortise Lock and its Cylinder: passo 7, imagem 1 %32 How to Change Mortise Lock and its Cylinder: passo 7, imagem 2 %32 How to Change Mortise Lock and its Cylinder: passo 7, imagem 3 %32
    • Grasp the mortise lock on either side and pull it out from the edge of the door.
Conclusão
Uma outra pessoa concluiu este guia.
Hikmat Guliyev
Membro desde: 01/16/21
172 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 60
Ao todo: 3,441
