Ir para o conteúdo principal
How to Calibrate an Optical Fingerprint Sensor
  1. How to Calibrate an Optical Fingerprint Sensor, Download the app: passo 1, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Download the app: passo 1, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor, Download the app: passo 1, imagem 3 %32
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Calibrate an Optical Fingerprint Sensor, Install the app: passo 2, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Install the app: passo 2, imagem 2 %32
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Calibrate an Optical Fingerprint Sensor, Rename the app: passo 3, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Rename the app: passo 3, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor, Rename the app: passo 3, imagem 3 %32
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Calibrate an Optical Fingerprint Sensor: passo 4, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor: passo 4, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor: passo 4, imagem 3 %32
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
  5. How to Calibrate an Optical Fingerprint Sensor, Open the Self Repair Assistant app: passo 5, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Open the Self Repair Assistant app: passo 5, imagem 2 %32
    • Open the Self Repair Assistant app.
  6. How to Calibrate an Optical Fingerprint Sensor, Agree to the terms and conditions: passo 6, imagem 1 %32
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Calibrate an Optical Fingerprint Sensor, Select the procedure: passo 7, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Select the procedure: passo 7, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor, Select the procedure: passo 7, imagem 3 %32
    • Select the "Display" icon.
    • Select "Continue" at the bottom of the screen.
    • If you want to perform a battery cycle reset instead, follow this guide.
    • Select "Start" to begin the fingerprint sensor calibration.
  8. How to Calibrate an Optical Fingerprint Sensor, Begin the fingerprint sensor calibration: passo 8, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Begin the fingerprint sensor calibration: passo 8, imagem 2 %32
    • Once the screen turns black, select "Start" again.
  9. How to Calibrate an Optical Fingerprint Sensor, Apply the white box: passo 9, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Apply the white box: passo 9, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor, Apply the white box: passo 9, imagem 3 %32
    • Place the white box over the outline near the bottom of the screen.
    • Cover the outline with the side on the box that matches the pattern.
    • Make sure the white box completely covers the outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  10. How to Calibrate an Optical Fingerprint Sensor: passo 10, imagem 1 %32
    • Use your finger to press down on the white box.
    • While pressing down, use your other hand to select the "Next" icon near the top of the screen.
    • Continue pressing until the "Calibrating" disappears.
  11. How to Calibrate an Optical Fingerprint Sensor, Apply the black box: passo 11, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Apply the black box: passo 11, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor, Apply the black box: passo 11, imagem 3 %32
    • Place the black box over the outline near the bottom of the screen.
    • Make sure the black box completely covers the outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  12. How to Calibrate an Optical Fingerprint Sensor: passo 12, imagem 1 %32
    • Use your finger to press down on the black box.
  13. How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: passo 13, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: passo 13, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: passo 13, imagem 3 %32
    • Place the side of the small white box with the grooves over the inner portion of the outline near the bottom of the screen.
    • Make sure the grooves on the box are vertical when placing it on the screen.
    • Make sure the white box completely covers the inner outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  14. How to Calibrate an Optical Fingerprint Sensor: passo 14, imagem 1 %32 How to Calibrate an Optical Fingerprint Sensor: passo 14, imagem 2 %32 How to Calibrate an Optical Fingerprint Sensor: passo 14, imagem 3 %32
    • Use your finger to press down on the small white box.
    • Continue pressing until "Done" appears at the top of the screen.
    • You may need to reset your device for the calibration to apply.
Conclusão
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
45 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
213.563 Reputação
Autoria de 1.040 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.649 guias
22Comentários do guia
When I open the app after installation I get this toast message "this model is NOT supported"
My device is a Galaxy A71
Pierre Ehab - Responder
I have a Galaxy A70. "Fingerprint sensor Calibration needed" when I try to turn on Biometric. *# 0 *# says the sensor is alright (everything pass) But calibration = 1
HOW do I calibrate the sensor? The local samsung service center is trash
nombre20 apellido20 -
When I open the app after installation I get this toast message "this model is NOT supported" My device is a Galaxy A52
neskagu nikomu - Responder
Hi there.
Unfortunately, as stated in the introduction, the only device supported right now is the Tab S7+ . Samsung plans to include more devices with time.
Alex Diaz-Kokaisl -
It showed not supported for this model... What should i do next
Salem Ekwuribe - Responder
Comentar
Visualizações:
Últimas 24 horas: 67
Últimos 7 dias: 491
Últimos 30 dias: 2,429
Ao todo: 203,319
