Introdução
If you've tried multiple methods to bypass frp S8 SM-G950, and unable to bypass frp lock, because off course new security patch level now biting difficult to bypass google account, after doing so many steps then I am successfully bypassed google account Samsung S8 SM-G950 so that's why I've decided to share with you guys new method to bypass frp on S8 SM-G950.
This method has been tested with [S8 SM-G950W Android 8].
Steps:-
-First, you need power off your device...
-Then put your Device in Recovery Mode.[Press & hold Vol UP+Bixby Key+ Power Key] When you see android logo release all the keys.
- After some time you will see the Recovery Menu on your device.
-Check your Device Firmware version and bootloader version.
-Then download your device Combination Firmware form Below.
Download Samsung G950F Combination Firmware
After that, you need to flash combination firmware
Download Odin from Below.
Then Extract Odin and G950F combination Firmware on your Computer.
After that, Open Odin extracted folder.
Then, Run Odin.exe
Click on "AP" tab and select Combination file.
Then Put your device in Recovery Mode.[Press and hold Volume Down + Bixby key + Power key] Confirm to press Volume UP key.
Then Connect your device to PC.
-After that you will see "added" massage On Odin log box.
-Then tap on "Start" button on Odin tool.
-Wait for flashing finished.
-Then Power On your Device.
-Then Swipe down your finger to bring Notification Menu.
-Then tap on the Settings icon.
-Then go down - About device - software info.
-then tap build number 7 times.
-Then go back to the settings menu.
-Goto developer menu.
-enable Oem unlocking and USB debugging.
Then back to combination main menu.
-then tap on IME Option.
Then Put *#0808#
Then select DM+ACM+ADB
-Then tap on reboot.
-After power on.
-Connect your device again in PC.
-Download FRP Tool By GD.
-Extract and Run FRP tool (GD)
-wait for completion.
-After that, Download Samsung S8 SM-G950 stock firmware from below
Now Flash Stock firmware on your Device ..
Details Guides:-Bypass FRP Samsung S8 check below
Done...
Download:-
FRP Tools+ All S8 Stock and Combination File link below
-Samsung S8 Bypass Google Account
Conclusão
Any query comment below, I try to solve your problem as soon as possible
2 outras pessoas concluíram este guia.
GD18
41 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 92
Todo: 92
