Ir para o conteúdo principal
How to Boot a Mac Into Safe Mode
  1. How to Boot a Mac Into Safe Mode, Shut Down: passo 1, imagem 1 %32
    • Shut down your Mac.
    • If you cannot boot your Mac to shut it down properly, press and hold the power button for 15 seconds. Your display, keyboard backlight and any fans should be off.
    • If you have an Apple Silicon based MacBook (any model newer than Late 2020), skip ahead to Step 5 since the process is a bit different.
  2. How to Boot a Mac Into Safe Mode, Boot Up In Safe Mode: passo 2, imagem 1 %32
    • Once the computer is completely shut down, press the power button, then immediately press and hold the Shift Key.
  3. How to Boot a Mac Into Safe Mode, Load Screen: passo 3, imagem 1 %32
    • The Apple logo and progress bar appear, just as they do in normal boot mode.
    • You may get a brief flash where the Apple logo turns red, or another color. This is normal.
  4. How to Boot a Mac Into Safe Mode, Log In: passo 4, imagem 1 %32
    • The macOS login screen will appear, as normal, but Safe Boot should appear in the upper right corner of the screen.
    • If FileVault is enabled you may need to log in twice. The first log unlocks your disk. The second times logs in your user account and is where the Safe Boot text will appear.
  5. How to Boot a Mac Into Safe Mode, Apple Silicon Macs: passo 5, imagem 1 %32
    • Apple Silicon Macs use a slightly different process for accessing Safe Mode.
    • As with Intel based Macs, power your Mac off.
    • Press and hold the Power button on your Mac until you see the "Loading startup options" text on screen.
  6. How to Boot a Mac Into Safe Mode, Startup Options: passo 6, imagem 1 %32
    • Once startup Options loads, you will see any valid startup disks connected to your Mac and the Options menu.
    • To access Safe Mode, select the disk you wish to boot from.
    • Press and hold the Shift key, the Continue button under your startup drive should change to "Continue in Safe Mode." Click it to initialize Safe Boot.
    • Everything after this point mimics the Intel method. You'll need to wait for the device to boot and login.
Conclusão
Now that your machine is in Safe Mode, attempt to recreate your issue without fear of interference from other apps.
11 outras pessoas executaram este guia.
Alisha C
Membro desde: 12/04/20
41.448 Reputação
Autoria de 9 guias
Equipe
LGBTQ Technicians Membro de LGBTQ Technicians
Community
47 Membros
Autoria de 77 guias
2Comentários do guia
can you create a mac osx OCLP install image onto a USB from one machine (say a MBP M1) that will be used to install Mac OSX on another machine (say a MBP 2011)? the process as described above has the user going thru reboots after the USB is created and picking the USB EFI boot ...I assume that in this example, on the macbook air being used, you were upgrading it with OSX 13.1....correct?
Wendell MacKenzie - Responder
Yes, but it depends on the machines at your disposal. As long as the version you are making the installer for was supported on the model of Mac you're using to make the installer. It generally will not allow you to make an installer for a version of macOS earlier than the machine will run, or newer than the machine will run.
Alisha C -
Comentar
Visualizações:
Últimas 24 horas: 70
Últimos 7 dias: 474
Últimos 30 dias: 2,481
Ao todo: 125,824
