Ir para o conteúdo principal
How to Alter the Waist of Jeans
O que você precisa
  1. How to Alter the Waist of Jeans, How to Alter the Waist of Jeans: passo 1, imagem 1 %32
    • Put on the jeans and pinch the extra fabric at the centre back of the waistband.
  2. How to Alter the Waist of Jeans: passo 2, imagem 1 %32
    • Mark both sides of the pinched fabric with chalk on the outside of the jeans.
    • You may do this step while wearing the jeans.
  3. How to Alter the Waist of Jeans: passo 3, imagem 1 %32 How to Alter the Waist of Jeans: passo 3, imagem 2 %32 How to Alter the Waist of Jeans: passo 3, imagem 3 %32
    • Draw a diagonal line from each marked spot to the centre back seam.
  4. How to Alter the Waist of Jeans: passo 4, imagem 1 %32 How to Alter the Waist of Jeans: passo 4, imagem 2 %32
    • Pass the thread through the loop on the needle threader.
    • Pull the needle threader out of the eye of the needle and create a knot at the end.
    • Use a double thread or a thick thread for durability.
    • For more information on using a needle threader, use the How to Use a Needle Threader Guide.
  5. How to Alter the Waist of Jeans: passo 5, imagem 1 %32 How to Alter the Waist of Jeans: passo 5, imagem 2 %32
    • Begin sewing from the inside out, starting beside the belt loop.
    • Bring the needle across the marked spot and sew it inside out.
  6. How to Alter the Waist of Jeans: passo 6, imagem 1 %32 How to Alter the Waist of Jeans: passo 6, imagem 2 %32
    • Move the needle horizontally, then insert and thread it through the fabric a short distance below the starting point.
    • Repeat this process until the thread reaches the centre back seam.
  7. How to Alter the Waist of Jeans: passo 7, imagem 1 %32 How to Alter the Waist of Jeans: passo 7, imagem 2 %32 How to Alter the Waist of Jeans: passo 7, imagem 3 %32
    • Pull the thread to conceal the stitches.
  8. How to Alter the Waist of Jeans: passo 8, imagem 1 %32 How to Alter the Waist of Jeans: passo 8, imagem 2 %32
    • Bring the thread back to the inside of the jeans, tie a knot, and cut the excess thread.
  9. How to Alter the Waist of Jeans: passo 9, imagem 1 %32
    • Repeat steps 4-8 on the other side.
Conclusão
Zoe Kim
Membro desde: 09/19/23
179 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 79
Últimos 30 dias: 244
Duração total: 1,234
