Introdução
Consider adjusting the action and intonation of a guitar or bass if you experience difficulty with fine tuning or string resistance. This guide can help if pressing guitar or bass strings is difficult, or if your instrument’s tone seems off despite being in tune. Adjusting the guitar neck and string action can make playing easier while enriching the instrument’s tone!
Before beginning this guide, detune your guitar strings, leaving room for the strings to be manipulated without snapping.
O que você precisa
Locate the truss rod, found either on the headstock, under a plate in the headstock, or on the body towards the base of the neck.
Check guitar intonation by listening to the twelfth fret notes and the twelfth fret harmonic of each string.
With a screwdriver, turn the screws below the saddles clockwise if the fretted note sounds higher pitched than the harmonic; turn them counterclockwise if the fretted notes is lower pitched than the harmonic.
Now enjoy your guitar!
