Ir para o conteúdo principal
How to Adjust a Violin Bow
  1. How to Adjust a Violin Bow, How to Adjust a Violin Bow: passo 1, imagem 1 %32 How to Adjust a Violin Bow, How to Adjust a Violin Bow: passo 1, imagem 2 %32
    • Identify the adjusting screw at the butt end of the bow.
  2. How to Adjust a Violin Bow: passo 2, imagem 1 %32
    • Carefully unscrew the adjusting screw .
  3. How to Adjust a Violin Bow: passo 3, imagem 1 %32
    • Once you fully unscrew the adjusting screw, carefully remove both the frog and the adjusting screw from the bow.
  4. How to Adjust a Violin Bow: passo 4, imagem 1 %32
    • While not allowing the hair to become tangled, insert a small part of the adjusting screw so that only a small portion of the tip is seen. You do not need to screw the adjusting screw into the eyelet.
  5. How to Adjust a Violin Bow: passo 5, imagem 1 %32 How to Adjust a Violin Bow: passo 5, imagem 2 %32
    • Carefully move the adjusting screw to tighten the eyehole, moving in a clockwise direction. To loosen, move the eyehole in a counter-clockwise direction.
    • Do not screw more than 180 degrees during adjustment to ensure you do not damage the bow.
  6. How to Adjust a Violin Bow: passo 6, imagem 1 %32
    • Once you have either tightened or loosened the eyehole by 180 degrees, remove the adjusting screw from the eyehole.
    • Once you have finished, make sure the hairs are not tangled and have not become damaged during the adjusting process.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 1,127
