Ir para o conteúdo principal
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
O que você precisa
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 1, imagem 1 %32
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 2, imagem 1 %32
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 3, imagem 1 %32 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 3, imagem 2 %32
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 4, imagem 1 %32
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 5, imagem 1 %32 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 5, imagem 2 %32
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 6, imagem 1 %32
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 7, imagem 1 %32 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 7, imagem 2 %32 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 7, imagem 3 %32
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
Linha de Chegada
Md Abdullah
Membro desde: 07/03/21
201 Reputação
Autoria de 1 guia
Um comentário
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 60
Últimos 30 dias: 202
Duração total: 4,656
