Ir para o conteúdo principal
How to Adjust Cantilever Bicycle Brakes
O que você precisa
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: passo 1, imagem 1 %32 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: passo 1, imagem 2 %32 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: passo 1, imagem 3 %32
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: passo 2, imagem 1 %32 How to Adjust Cantilever Bicycle Brakes: passo 2, imagem 2 %32
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: passo 3, imagem 1 %32 How to Adjust Cantilever Bicycle Brakes: passo 3, imagem 2 %32 How to Adjust Cantilever Bicycle Brakes: passo 3, imagem 3 %32
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: passo 4, imagem 1 %32
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: passo 5, imagem 1 %32 How to Adjust Cantilever Bicycle Brakes: passo 5, imagem 2 %32
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: passo 6, imagem 1 %32 How to Adjust Cantilever Bicycle Brakes: passo 6, imagem 2 %32
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: passo 7, imagem 1 %32 How to Adjust Cantilever Bicycle Brakes: passo 7, imagem 2 %32
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: passo 8, imagem 1 %32
    • Flip the bike back onto its wheels.
Conclusão
Go ride your bike!
Uma outra pessoa concluiu este guia.
Devaughantee
Membro desde: 09/30/20
194 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 811
