Ir para o conteúdo principal
How do I replace the wheels on my Tobago trolley?
O que você precisa
  1. How do I replace the wheels on my Tobago trolley?, Wheels: passo 1, imagem 1 %32 How do I replace the wheels on my Tobago trolley?, Wheels: passo 1, imagem 2 %32 How do I replace the wheels on my Tobago trolley?, Wheels: passo 1, imagem 3 %32
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: passo 2, imagem 1 %32 How do I replace the wheels on my Tobago trolley?: passo 2, imagem 2 %32
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: passo 6, imagem 1 %32 How do I replace the wheels on my Tobago trolley?: passo 6, imagem 2 %32 How do I replace the wheels on my Tobago trolley?: passo 6, imagem 3 %32
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
Conclusão
Follow the instructions in reverse order to finish the repair.
VAUDE Reparaturteam
Membro desde: 02/22/16
6.279 Reputação
Autoria de 32 guias
Equipe
Vaudesport Membro de Vaudesport
Community
Membros da 3
Autoria de 96 guias
3 comentários
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - Responder
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 70
Duração total: 4,921
