Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Can iPhone 11 Pro possibly be turned into iPhone 11 Pro Max? It is actually theoretically possible. With pins of the two phones’ display connector and touch connector functioning almost the same, we can turn an iPhone 11 Pro into an iPhone 11 Pro Max by changing board ID resistors.
Vídeo de Apresentação
  1. iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro comes with a 5.80-inch touchscreen display.
    • iPhone 11 Pro Max comes with a 6.50-inch touchscreen display.
  2. What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
    • What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Comprar agora
    Comprar agora
  4. Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • All we need to do is remove the extra board ID resistor.
  5. We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
    • We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
Phryne
Membro desde: 17/11/2019
14.796 Reputação
80 Guias de autoria
Very impressive. Thanks a lot!
viona - Responder
hope it can help you somehow!
Phryne -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 115
Duração total: 2,002
