Ir para o conteúdo principal
How To True A Bicycle Wheel
O que você precisa
Vídeo de Apresentação
  1. How To True A Bicycle Wheel, How To True A Bicycle Wheel: passo 1, imagem 1 %32
    • Put the rim and align into the truing stand.
  2. How To True A Bicycle Wheel: passo 2, imagem 1 %32
    • Second, grab lubricant.
  3. How To True A Bicycle Wheel: passo 3, imagem 1 %32
    • Notice how each nipple is void of lube. In this step add the lube to each individual nipple.
  4. How To True A Bicycle Wheel: passo 4, imagem 1 %32
    • Once you have completed the previous task, loosen the truing knob.
    • This will make the truing arms open.
    • Give it a spin! The centrifical force lubes up the threads, making it easier to begin truing.
    • Notice the spoke wrenches; they will be required in our next step.
  5. How To True A Bicycle Wheel: passo 5, imagem 1 %32
    • Use the truing knob to determine how fine the truing arms (red) need to be. In this case, I am truing finely down to the millimeter.
  6. How To True A Bicycle Wheel: passo 6, imagem 1 %32
    • Here the spoke tool (red) will be needed. After giving it a spin, I noticed that it deviated far too much to the left. You will know this by hearing which side scrapes against the truing arm. (orange)
    • Use the spoke wrench (red) to tighten the spokes (yellow). It is good practice to tighten the spoke before and after on the side that needs truing.
    • Lastly, keep truing tire until the range of deviation is good to you. This process for a "quick-fix" can be as little as 30min-1 hour.
    • Experienced cyclists may vary from days to weeks to completely true their tire.
Conclusão
Elijah W
Membro desde: 10/16/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 103
