Ir para o conteúdo principal
How To Transfer Content To Your New 3DS XL
O que você precisa
Vídeo de Apresentação
  1. How To Transfer Content To Your New 3DS XL, How To Transfer Content To Your New 3DS XL: passo 1, imagem 1 %32
    • Start by removing the stylus from the frame of the New 3DS XL.
  2. How To Transfer Content To Your New 3DS XL: passo 2, imagem 1 %32 How To Transfer Content To Your New 3DS XL: passo 2, imagem 2 %32 How To Transfer Content To Your New 3DS XL: passo 2, imagem 3 %32
    • Loosen the two captive Phillips #1 screws on the back of the device.
    • These captive screws will conveniently stay in the rear cover, so don't try to remove them.
    • Prying from the thumb slots on each side, pull the rear panel off the back of the device.
  3. How To Transfer Content To Your New 3DS XL: passo 3, imagem 1 %32
    • Press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Use a PC to copy the data from the source SD card to the New 3DS XL microSD card.
    • You may need a micro SD to SD adapter.
    • For reassembly, push the microSD card into the slot until it clicks in place.
Conclusão
4 outras pessoas executaram este guia.
Geoff Wacker
Membro desde: 09/30/13
90.313 Reputação
Autoria de 89 guias
Um comentário
Can anyone who's actually tried the text portion of this guide confirm whether it works? As I understand it, all the data on a 3ds is encrypted with a console-specific key (movable.sed) to prevent exactly this. If it actually worked like this, wouldn't it defeat copy protection almost entirely since any o3ds encrypted ROM could just be copied as-is to a n3ds and run normally?
darth mango - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 82
Duração total: 5,962
