Introdução
For travel, luggage is an indispensable item. During the trip, we must set a password for the suitcase to ensure the safety of the contents. But the password can be easily forgotten and neglected, so opening the suitcase is a more difficult thing. If you do forget the combination, follow this guide to reset the combination on your suitcase lock.
Set the suitcase down with the combination lock facing up.
Hi . I tried the method . There are small little dent like thing ( ig groove ) on the 444 combination ( on each 4 4 4 gear ) . Then I started to add each gear by 1-9 simultaneously. But still It didn't open
Kindly help
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
5 outras pessoas executaram este guia.
4Comentários do guia
OMG! A big THANK YOU!!! It worked.
Amazing. This worked for me
It worked for me too
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
