Ir para o conteúdo principal
How To Replace Ski Pole Baskets
O que você precisa
  1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: passo 1, imagem 1 %32 How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: passo 1, imagem 2 %32
    • Place the sock over your hand like a glove.
    • You will be using this hand to pull off the heated basket.
  2. How To Replace Ski Pole Baskets: passo 2, imagem 1 %32 How To Replace Ski Pole Baskets: passo 2, imagem 2 %32
    • Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
    • Heat for no longer then three minutes.
  3. How To Replace Ski Pole Baskets: passo 3, imagem 1 %32 How To Replace Ski Pole Baskets: passo 3, imagem 2 %32
    • Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
  4. How To Replace Ski Pole Baskets: passo 4, imagem 1 %32 How To Replace Ski Pole Baskets: passo 4, imagem 2 %32
    • Heat an all purpose glue stick with a lighter.
  5. How To Replace Ski Pole Baskets: passo 5, imagem 1 %32 How To Replace Ski Pole Baskets: passo 5, imagem 2 %32
    • Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
    • Press the new basket immediately after applying the melted glue in order to obtain maximum adhesion.
  6. How To Replace Ski Pole Baskets: passo 6, imagem 1 %32
    • Reheat the replaced basket with a hair dryer for a minute.
    • After heating, allow the glue to cool and set for 10 minutes.
  7. How To Replace Ski Pole Baskets: passo 7, imagem 1 %32
    • After drying for 10 minutes, your poles will be ready for use. Happy Skiing!
Conclusão
Uma outra pessoa concluiu este guia.
Lia Garkie
Membro desde: 04/09/15
131 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 30-3, Green Spring 2015 Membro de Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 17,083
