Ir para o conteúdo principal
How To Replace Burners on Weber Genesis II Grill
O que você precisa
  1. How To Replace Burners on Weber Genesis II Grill, Burners: passo 1, imagem 1 %32 How To Replace Burners on Weber Genesis II Grill, Burners: passo 1, imagem 2 %32 How To Replace Burners on Weber Genesis II Grill, Burners: passo 1, imagem 3 %32
    • This is the Weber Genesis II grill. Before replacement of the burner, we will start by cleaning the grates with a grill brush in order to be clean and safe.
    • Make sure that the grill is completely turned off so there is no chance of accidental burn.
  2. How To Replace Burners on Weber Genesis II Grill: passo 2, imagem 1 %32 How To Replace Burners on Weber Genesis II Grill: passo 2, imagem 2 %32 How To Replace Burners on Weber Genesis II Grill: passo 2, imagem 3 %32
    • Remove the grates using your hands.
    • Grab on each side of the grill grate with your hands and lift straight upwards.
    • Set the removed grate off to the side of the grill.
    • Repeat this procedure for all three of the grates on top of the grill.
  3. How To Replace Burners on Weber Genesis II Grill: passo 3, imagem 1 %32 How To Replace Burners on Weber Genesis II Grill: passo 3, imagem 2 %32 How To Replace Burners on Weber Genesis II Grill: passo 3, imagem 3 %32
    • Remove the heat deflector plates from on top of the burners.
    • Grab each deflector plate and pull straight upwards as with the grates.
    • Place the removed heat deflector plates off to the side of the grill.
    • Repeat this procedure for all heat deflector plates until each burner is exposed.
    • Only half of the heat deflectors plates will have burners underneath them. So do not be alarmed when not all plates have a burner.
  4. How To Replace Burners on Weber Genesis II Grill: passo 4, imagem 1 %32 How To Replace Burners on Weber Genesis II Grill: passo 4, imagem 2 %32 How To Replace Burners on Weber Genesis II Grill: passo 4, imagem 3 %32
    • Remove the burner from its slot in the back of the grill.
    • With both hands, carefully pull the burner upwards and slightly to the left in order to pull it out of its slot.
    • The burners can become stuck and require a little extra force to pull out, but do not pull too hard and hit the top of the grill or yourself.
    • If replacing all burners, repeat this procedure to remove all burners from their slots.
  5. How To Replace Burners on Weber Genesis II Grill: passo 5, imagem 1 %32 How To Replace Burners on Weber Genesis II Grill: passo 5, imagem 2 %32 How To Replace Burners on Weber Genesis II Grill: passo 5, imagem 3 %32
    • Detach the burner from the ignition device.
    • With a small wedge, such as a flat-head screwdriver, unclip the white connector from the burner.
    • With the ignition device removed, you are now all set to replace the burner with a new one.
Conclusão
3 outras pessoas executaram este guia.
Nicholas Brown
Membro desde: 03/24/21
202 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 52
Últimos 30 dias: 143
Duração total: 10,543
