Ir para o conteúdo principal
How To Repair An Overheating D-LINK DIR-655 Wireless Router
O que você precisa
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 1, imagem 1 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 1, imagem 2 %32
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 2, imagem 1 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 2, imagem 2 %32
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 3, imagem 1 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 3, imagem 2 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 3, imagem 3 %32
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 4, imagem 1 %32
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 5, imagem 1 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 5, imagem 2 %32
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 6, imagem 1 %32
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 7, imagem 1 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 7, imagem 2 %32 How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 7, imagem 3 %32
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 8, imagem 1 %32
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: passo 9, imagem 1 %32
    • Wipe away any dust from the the vents to ensure proper airflow.
Conclusão
6 outras pessoas executaram este guia.
Chance Daniel
Membro desde: 09/29/15
263 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-6, Green Fall 2015 Membro de Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
Membros da 3
Autoria de 3 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 5,507
