Introdução
Baseboards often suffer from paint stains during wall painting or renovation projects. Over time, these stains can detract from the appearance of your room, making it look untidy. This guide will show you how to safely and effectively remove old paint stains from baseboards and restore them to their original condition, without damaging the wood. You’ll learn a step-by-step process using common tools and materials, making this a task anyone can accomplish.
O que você precisa
Lay down a drop cloth or plastic sheeting to protect the floor from dust and paint.
Use painter's tape to mask off the edges where the baseboard meets the wall and the floor to prevent damage to other surfaces.
Use a paint brush to apply a coat of primer to the sanded and repaired area to ensure the paint adheres well.
Use a small paintbrush to apply paint to the repaired area, ensuring an even coat. Select a paint that matches the existing color of the baseboard for a seamless finish.
Apply a thin, even coat and let it dry completely before applying additional coats if necessary.
