Introdução
If your hardwood floor has a few scratches that are standing out and you don’t want to refinish the whole thing, follow this guide to remove scratches from your floor. Whether from heels, animal paws, toys, or daily wear, hardwood floors can take a beating. Sometimes they look good overall and there’s just one scratch that you just can’t stand to look at anymore because it sticks out on the dark wood stain or you just really want to hide it from the company that’s coming over. Whatever the reason, this short guide will help you cover those small scratches.
O que você precisa
Identify the scratch you would like to repair.
Apply wood filler into the scratch using a putty knife.
Excellent post! Buckling is when your hardwood floor pulls up and separates from the subfloor. While it's not a common occurrence, buckling happens after a hardwood floor has been flooded or exposed to moisture, like a spill or flood, and left untreated. Thank you.
Ferramenta utilizada nesse passo:Microfiber Cleaning Cloths$3.99
After drying completely, apply some wipe on polyurethane to a microfiber cloth or towel.
Buff the area with the cloth.
The scratch will hardly be noticeable after this repair. Depending on the depth of the scratch, it is possible this fix will not make the floor look good as new. For very deep scratches the only remedy may be to replace the floor board.
