Ir para o conteúdo principal
How To Remove Hardened Masking Tape From Car Paint
O que você precisa
  1. How To Remove Hardened Masking Tape From Car Paint, How To Remove Hardened Masking Tape From Car Paint: passo 1, imagem 1 %32
    • Goo Gone can be harmful to skin after prolonged exposure so be sure to have your gloves on during this entire process.
    • Spray the paper towel 2 times with the Goo Gone.
    • Be sure to turn the nozzle into the "on" position.
    Pergunte ao FixBot
    Comentar
  2. How To Remove Hardened Masking Tape From Car Paint: passo 2, imagem 1 %32
    • Press the wet paper towel against the hardened tape for about 30 seconds.
    • This will soften the tape.
    Pergunte ao FixBot
    Comentar
  3. How To Remove Hardened Masking Tape From Car Paint: passo 3, imagem 1 %32 How To Remove Hardened Masking Tape From Car Paint: passo 3, imagem 2 %32
    • Aggressively scrub the tape for about 10 seconds.
    Pergunte ao FixBot
    Comentar
  4. How To Remove Hardened Masking Tape From Car Paint: passo 4, imagem 1 %32 How To Remove Hardened Masking Tape From Car Paint: passo 4, imagem 2 %32
    • Repeat steps 2 and 3 until all of the adhesive residue has been removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Now that you have successfully removed the tape for your car, it is recommended that you wash your car to get rid of the Goo Gone remnants. Who doesn't love a clean car, anyway?
8 outras pessoas executaram este guia.
Jami Hahn
Membro desde: 02/23/15
371 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-4, Green Winter 2015 Membro de Cal Poly, Team 12-4, Green Winter 2015
CPSU-GREEN-W15S12G4
5 Membros
Autoria de 10 guias
1Comentário do guia
This masking tape has been on the side of this old VW for years will googone still take off several layers of it ?
Randy Verburg - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 91
Ao todo: 38,144
