Ir para o conteúdo principal
How To Re-String A Hoodie
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. How To Re-String A Hoodie, How To Re-String A Hoodie: passo 1, imagem 1 %32 How To Re-String A Hoodie, How To Re-String A Hoodie: passo 1, imagem 2 %32
    • Uncoil the wire coat hanger into a straight line.
  2. How To Re-String A Hoodie: passo 2, imagem 1 %32 How To Re-String A Hoodie: passo 2, imagem 2 %32 How To Re-String A Hoodie: passo 2, imagem 3 %32
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. How To Re-String A Hoodie: passo 3, imagem 1 %32
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. How To Re-String A Hoodie: passo 4, imagem 1 %32
    • Feed the wire through the hoodie until it reaches the top of the hood.
  5. How To Re-String A Hoodie: passo 5, imagem 1 %32 How To Re-String A Hoodie: passo 5, imagem 2 %32
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  6. How To Re-String A Hoodie: passo 6, imagem 1 %32 How To Re-String A Hoodie: passo 6, imagem 2 %32
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  7. How To Re-String A Hoodie: passo 7, imagem 1 %32 How To Re-String A Hoodie: passo 7, imagem 2 %32
    • Remove the tape from the end of the wire and string.
  8. How To Re-String A Hoodie: passo 8, imagem 1 %32 How To Re-String A Hoodie: passo 8, imagem 2 %32
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  9. How To Re-String A Hoodie: passo 9, imagem 1 %32
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
Conclusão
Congratulations on restringing your hoodie!
4 outras pessoas executaram este guia.
Ashley
Membro desde: 02/24/15
267 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-1, Green Winter 2015 Membro de Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
Membros da 4
Autoria de 4 guias
Um comentário
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 272
