Ir para o conteúdo principal
How To Patch a Hole in Umbrella Fabric
O que você precisa
  1. How To Patch a Hole in Umbrella Fabric, Fabric: passo 1, imagem 1 %32
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: passo 2, imagem 1 %32
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: passo 3, imagem 1 %32
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: passo 4, imagem 1 %32
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: passo 5, imagem 1 %32
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: passo 6, imagem 1 %32
    • Apply your patch squarely over the torn fabric.
Conclusão
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
Membro desde: 10/04/20
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 123
Ao todo: 19,507
