Ir para o conteúdo principal
How To Open A Desktop Hard Drive
O que você precisa
  1. How To Open A Desktop Hard Drive, Remove The Front Screws: passo 1, imagem 1 %32 How To Open A Desktop Hard Drive, Remove The Front Screws: passo 1, imagem 2 %32
    • Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
  2. How To Open A Desktop Hard Drive, Removing The Hidden Screws: passo 2, imagem 1 %32 How To Open A Desktop Hard Drive, Removing The Hidden Screws: passo 2, imagem 2 %32
    • There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
    • Please check under the sticker before you open up your disk drive. I didn't, and went full brute-force on the hard drive cover. Whoops!
  3. How To Open A Desktop Hard Drive: passo 3, imagem 1 %32 How To Open A Desktop Hard Drive: passo 3, imagem 2 %32
    • Slide a spudger around the front cover to remove any adhesive or rubber insulation before opening.
  4. How To Open A Desktop Hard Drive: passo 4, imagem 1 %32
    • Gently remove the cover.
    • Do NOT do what I did, please.
  5. How To Open A Desktop Hard Drive: passo 5, imagem 1 %32
    • There you have it! Now you have a fully-opened hard drive. Whether you want to make a pretty cool (and large) paperweight or perma-delete your data, you can now do so.
Conclusão
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
6 outras pessoas executaram este guia.
gamer_Kat
Membro desde: 11/11/23
271 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 51
Últimos 30 dias: 268
Ao todo: 895
