Ir para o conteúdo principal
How To Maintain The Cooker Hood In Your Appliance
O que você precisa
    • Unplug the appliance from any electrical source before starting any maintenance.
    Pergunte ao FixBot
    Comentar
    • Detach the grease filter if it is still in place and set it aside.
    • Unscrew or unclip any external panels to expose the interior components.
    • Wear protective gloves to avoid sharp edges and greasy surfaces.
    Pergunte ao FixBot
    Comentar
    • Locate and remove screws or clips securing the hood interior and lamp assembly.
    • Lift away plastic or metal covers to gain access to the motor housing.
    • Detach the lamp unit gently if present to protect the bulb and wiring.
    Pergunte ao FixBot
    Comentar
    • Remove any electrical components or cable holders from the casing.
    • Set aside circuit boards or switches to keep them dry during cleaning.
    • Keep fasteners and small parts in a secure container for reassembly.
    Pergunte ao FixBot
    Comentar
    • Apply a degreasing solution liberally to all hood surfaces and let it soak for approximately 5-6 hours.
    • Use caution around broken or cracked glass components to avoid cuts.
    • Rinse or wipe away any loosened buildup after soaking.
    Pergunte ao FixBot
    Comentar
    • Avoid submerging the motor in water to protect windings from damage.
    • Use a suitable solvent with a cloth or brush to remove built-up grease.
    • Disassemble the motor if needed by removing its securing bolts with care.
    • Keep track of clips and photograph their positions for reference.
    Pergunte ao FixBot
    Comentar
    • Soak metal panels, fan covers, and removable parts in hot water or a dishwasher.
    • Inspect for sharp edges to prevent injuries during scrubbing and rinsing.
    • Dry all components thoroughly before moving on to reassembly.
    Pergunte ao FixBot
    Comentar
    • Lubricate bushings and the motor shaft lightly with appropriate machine oil.
    • Realign the rotor, stator, and washers, ensuring each part is in its original place.
    • Tighten bolts or nuts evenly and check for smooth rotation without friction.
    Pergunte ao FixBot
    Comentar
    • Repair or reinforce any cracked lamp housing with suitable materials (duck tape, double-sided tape, aluminum foil).
    • Reattach the motor and all electrical components in reverse order of removal.
    • Reinstall the grease filter and secure all casing panels firmly.
    Pergunte ao FixBot
    Comentar
Conclusão
Maintaining your cooker hood keeps it operating at peak performance and extends its service life. Clean, lubricate, and inspect regularly to prevent excessive buildup and electrical issues. With routine care, the hood effectively removes odors and grease, promoting a safer and more pleasant cooking environment.
Uma outra pessoa concluiu este guia.
Ula Gantar
Membro desde: 01/08/25
16.609 Reputação
Autoria de 81 guias
Equipe
ZEOS Slovenia Membro de ZEOS Slovenia
Local Repair Groups
2 Membros
Autoria de 95 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 110
Ao todo: 1,743
