Ir para o conteúdo principal
How To Fix a Torn Book Page
O que você precisa
  1. How To Fix a Torn Book Page, How To Fix a Torn Book Page: passo 1, imagem 1 %32
    • Lay out all of the equipment needed for the repair.
  2. How To Fix a Torn Book Page: passo 2, imagem 1 %32
    • Place one piece of wax paper behind the torn page.
    • The wax paper is used to protect the other pages from the glue.
  3. How To Fix a Torn Book Page: passo 3, imagem 1 %32
    • Be very careful in aligning the torn piece with the page, as realignment after gluing will be difficult.
    • Make sure to align the torn pieces precisely. Placing them too closely or too far apart may create an issue in reading the pages later.
    • Align the torn pieces, so they connect the images/text accurately and neatly.
    • You may use a clamp to hold the torn pieces together to make gluing easier.
  4. How To Fix a Torn Book Page: passo 4, imagem 1 %32 How To Fix a Torn Book Page: passo 4, imagem 2 %32 How To Fix a Torn Book Page: passo 4, imagem 3 %32
    • Do not apply too much glue, only enough to evenly cover the tear between the page and the torn piece.
    • Remove any excess glue to prevent the pages from sticking to the wax paper.
    • Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
    • Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
  5. How To Fix a Torn Book Page: passo 5, imagem 1 %32
    • Place the second sheet of wax paper on top of the page you just glued.
    • Be careful when placing the wax paper on top of the wet glue. Moving the wax paper around will make the glue smear.
  6. How To Fix a Torn Book Page: passo 6, imagem 1 %32
    • Wrap the closed book with several rubber bands to squeeze and compress during drying time.
  7. How To Fix a Torn Book Page: passo 7, imagem 1 %32 How To Fix a Torn Book Page: passo 7, imagem 2 %32
    • You can also use several books or other heavy items to add extra weight.
  8. How To Fix a Torn Book Page: passo 8, imagem 1 %32 How To Fix a Torn Book Page: passo 8, imagem 2 %32
    • Let the glue dry for 6 hours minimum to ensure that it dries completely.
    • Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
Linha de Chegada
3 outras pessoas executaram este guia.
2Comentários do guia
Thanks for article!
Alex White - Responder
In the materials list, you state parchment paper. However, in the actual descriptions, you mentioned wax paper. Are both possible to use? What kind of wax paper is recommended? I’m not really clear about the discrepancy.
Joshua Boren - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 64
Últimos 30 dias: 324
Ao todo: 14,784
