Introdução
After being used multiple times a box cutter can become jammed. The blade becomes displaced inside of the box cutter which then makes it impossible to come out. This causes the box cutter to be jammed.
This guide demonstrates how to fix a jammed box cutter to make it usable again. You will be dealing with a sharp blade throughout this process so please be careful. All you need for this repair is a screwdriver. Once you have your screwdriver, you are ready to unjam a box cutter!
O que você precisa
Using a Phillips head screwdriver, unscrew the screw on the box cutter.
Remove the top part of the box cutter.
