Ir para o conteúdo principal
How To Fix a Burst Garden Hose
O que você precisa
  1. How To Fix a Burst Garden Hose, How To Fix a Burst Garden Hose: passo 1, imagem 1 %32 How To Fix a Burst Garden Hose, How To Fix a Burst Garden Hose: passo 1, imagem 2 %32
    • Cut the hose in half from the burst part.
    • When cutting, aim to be as straight as possible, removing all irregularities on both sides. Therefore, make sure when you are finished there are no mangled parts on either side of the newly cut hose.
    • Be careful when using heavy duty scissors. Watch the finger placement and don't cut anything too swiftly. Slow and steady wins the race and also prevents finger damage.
  2. How To Fix a Burst Garden Hose: passo 2, imagem 1 %32 How To Fix a Burst Garden Hose: passo 2, imagem 2 %32
    • Before inserting the hose clamp, make sure it is the appropriate size. For example, if the diameter of your hose is 3/4 inch, the hose clamp should be the same.
    • Now, insert the hose in the hose ring.
    • Though not needed, you can already use your screwdriver to tighten it up to prevent them from falling all the way to their opposite ends.
  3. How To Fix a Burst Garden Hose: passo 3, imagem 1 %32 How To Fix a Burst Garden Hose: passo 3, imagem 2 %32
    • Warm up both ends of the hose using a hair dryer.
    • Apply the heat liberally for 5-10 seconds.
    • It is an important step - it helps expand the hose, making it easier to insert the pipe - which is the next step.
  4. How To Fix a Burst Garden Hose: passo 4, imagem 1 %32 How To Fix a Burst Garden Hose: passo 4, imagem 2 %32 How To Fix a Burst Garden Hose: passo 4, imagem 3 %32
    • Insert the copper, steel or plastic pipe into both sides of the ruptured hose after it has cooled down from the previous step.
    • This step should be done as gently as possible to prevent it from further internal damage which will make it more susceptible to bursts in the future.
  5. How To Fix a Burst Garden Hose: passo 5, imagem 1 %32 How To Fix a Burst Garden Hose: passo 5, imagem 2 %32 How To Fix a Burst Garden Hose: passo 5, imagem 3 %32
    • Push both ends as close as possible together.
    • Do it in a controlled, circular manner, turning the wrists inwards as seen in the photo above.
    • Failing to insert the pipes gently and executing the step roughly can lead to further internal ruptures. Therefore, try to be as slow as possible.
  6. How To Fix a Burst Garden Hose: passo 6, imagem 1 %32 How To Fix a Burst Garden Hose: passo 6, imagem 2 %32 How To Fix a Burst Garden Hose: passo 6, imagem 3 %32
    • Move the ring clamps inwards towards the middle, aiming to keep a 1 inch distance between each other.
    • Use the flathead screwdriver to tighten the hose clamps as much as possible.
    • Not firmly lodging the clamps will make the hose still susceptible to further bursts.
Conclusão
3 outras pessoas executaram este guia.
Equipe
2 comentários
I wished I had seen this tutorial before throwing away two water hoses.
Jeff - Responder
Don’t feel bad. I did the repair and it still leaked!
Michelle Goad -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 73
Duração total: 1,532
