Ir para o conteúdo principal
How To Fix a Broken Wreath
O que você precisa
  1. How To Fix a Broken Wreath, How To Fix a Broken Wreath: passo 1, imagem 1 %32 How To Fix a Broken Wreath, How To Fix a Broken Wreath: passo 1, imagem 2 %32 How To Fix a Broken Wreath, How To Fix a Broken Wreath: passo 1, imagem 3 %32
    • Use floral wire to repair the base by wrapping it around the affected area.
    • Reattach the hanger while wrapping your base with floral wire.
    • Use hot glue for additional security if needed.
  2. How To Fix a Broken Wreath: passo 2, imagem 1 %32 How To Fix a Broken Wreath: passo 2, imagem 2 %32 How To Fix a Broken Wreath: passo 2, imagem 3 %32
    • Wrap any missing branches with floral wire.
    • Use hot glue to reattach the branches to the base.
  3. How To Fix a Broken Wreath: passo 3, imagem 1 %32 How To Fix a Broken Wreath: passo 3, imagem 2 %32 How To Fix a Broken Wreath: passo 3, imagem 3 %32
    • Wrap the base of the decoration with floral wire and wrap around the base.
    • Use hot glue to secure in place, but be careful to avoid melting any plastic.
  4. How To Fix a Broken Wreath: passo 4, imagem 1 %32 How To Fix a Broken Wreath: passo 4, imagem 2 %32 How To Fix a Broken Wreath: passo 4, imagem 3 %32
    • Use your glue gun to attach any other pieces that do not require floral wire to be attached, such as berries.
  5. How To Fix a Broken Wreath: passo 5, imagem 1 %32
    • Add any final touches that you wish to add. If the pieces attached are oddly colored, you may choose to spray them with craft snow or glitter to give them an even look.
    • Check over your wreath, add hot glue to any areas that need extra security.
    • Hang finished wreath up for decoration.
Linha de Chegada
Kimberly Lammers
Membro desde: 11/26/21
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 45
Ao todo: 775
