Ir para o conteúdo principal
How To Fix Ripped Sandals
O que você precisa
  1. How To Fix Ripped Sandals, How To Fix Ripped Sandals: passo 1, imagem 1 %32 How To Fix Ripped Sandals, How To Fix Ripped Sandals: passo 1, imagem 2 %32
    • Locate the tear(s) in the sandals.
  2. How To Fix Ripped Sandals: passo 2, imagem 1 %32 How To Fix Ripped Sandals: passo 2, imagem 2 %32 How To Fix Ripped Sandals: passo 2, imagem 3 %32
    • Pour some glue into the tear.
    • Turn the sandal over, and put some more glue on the underneath side of the tear.
    • Make sure all parts of the tear are covered with glue.
  3. How To Fix Ripped Sandals: passo 3, imagem 1 %32 How To Fix Ripped Sandals: passo 3, imagem 2 %32 How To Fix Ripped Sandals: passo 3, imagem 3 %32
    • While the glue is wet, press both sides of the sandal together.
    • Hold this for about 60 seconds or until the glue dries.
  4. How To Fix Ripped Sandals: passo 4, imagem 1 %32 How To Fix Ripped Sandals: passo 4, imagem 2 %32 How To Fix Ripped Sandals: passo 4, imagem 3 %32
    • If needed, put a thin layer of glue on both sides to make sure it does not rip open.
  5. How To Fix Ripped Sandals: passo 5, imagem 1 %32 How To Fix Ripped Sandals: passo 5, imagem 2 %32 How To Fix Ripped Sandals: passo 5, imagem 3 %32
    • Press together again.
    • Hold for about 60 seconds.
  6. How To Fix Ripped Sandals: passo 6, imagem 1 %32 How To Fix Ripped Sandals: passo 6, imagem 2 %32 How To Fix Ripped Sandals: passo 6, imagem 3 %32
    • If the area is not smooth after it has dries, use a nail filer to shave down the glue.
    • If you do not have a nail filer, sandpaper should work, too.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 35
Ao todo: 504
