Ir para o conteúdo principal
How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
O que você precisa
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: passo 1, imagem 1 %32
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: passo 2, imagem 1 %32
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: passo 3, imagem 1 %32
    • Reassemble and re-install the card into your computer. It should stop the vibration.
Conclusão
8 outras pessoas executaram este guia.
Matthew Johnson
Membro desde: 04/07/12
392 Reputação
Autoria de 1 guia
Um comentário
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 21
Duração total: 8,325
