Introdução
Do you have an LP record that is skipping? Use this guide to get your record back to sounding like new.
O que você precisa
Identify the problem area by playing the LP record on a turntable.
Note the damaged area.
After the LP Record is completely dry, you will be able to play and enjoy the repaired record.
If the LP record is not fixed, this could indict a deep scratch that will need to be repaired by a professional.
2 comentários
This is the worst advice I’ve ever read.
Did the method work though?!
