Ir para o conteúdo principal
How To Dye Faded Canvas Shoes
O que você precisa
  1. How To Dye Faded Canvas Shoes, How To Dye Faded Canvas Shoes: passo 1, imagem 1 %32 How To Dye Faded Canvas Shoes, How To Dye Faded Canvas Shoes: passo 1, imagem 2 %32
    • Mix a few drops of detergent with water in the bucket. You should add about 3 drops of detergent for every 10 oz of water.
    • Do not add too much detergent. If the solution becomes too bubbly or overly soapy, there is too much detergent in the solution.
  2. How To Dye Faded Canvas Shoes: passo 2, imagem 1 %32 How To Dye Faded Canvas Shoes: passo 2, imagem 2 %32
    • Dip entire scrubbing device (toothbrush or sponge) into solution.
    • Lightly scrub the faded material with the scrubbing device.
    • Be gentle. Do not scrub too hard. This will damage the suede shoe.
  3. How To Dye Faded Canvas Shoes: passo 3, imagem 1 %32 How To Dye Faded Canvas Shoes: passo 3, imagem 2 %32
    • Lightly tap the faded canvas carefully with a towel or paper towel to dry it
    • Again, be gentle with the material so you do not damage it.
    • Leave the shoe out to air dry. It should take about 1-2 hours to completely dry.
  4. How To Dye Faded Canvas Shoes: passo 4, imagem 1 %32
    • Dip the utensil into the dye. Completely cover the utensil in dye.
  5. How To Dye Faded Canvas Shoes: passo 5, imagem 1 %32 How To Dye Faded Canvas Shoes: passo 5, imagem 2 %32 How To Dye Faded Canvas Shoes: passo 5, imagem 3 %32
    • Apply the dye to the faded area of the shoe.
    • Apply lightly over the entire surface of faded area in a circular motion.
    • Be careful not to get any dye on your skin.
  6. How To Dye Faded Canvas Shoes: passo 6, imagem 1 %32 How To Dye Faded Canvas Shoes: passo 6, imagem 2 %32
    • Allow the dye to dry.
    • Refer to the canvas dye directions for drying time. It should take about 1-2 hours to be completely dry.
Conclusão
When the color of your shoes has been completely restored, you are finished. For other shoe related issues, there are other guides on iFixit that can help.
17 outras pessoas executaram este guia.
Ryan Thomson
Membro desde: 04/09/15
737 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 28-6, Green Spring 2015 Membro de Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
Membros da 4
Autoria de 11 guias
5 comentários
The color had faded due to display for a period of time, how to restore its color as it is a stripe one
joyjpastoral - Responder
how long this color work on product i means what is their age i found some good detail for dye please check and let me know is correct or not ?
Munna Dyes Chem
Munna Dyes - Responder
The colour has faded due to washing them how to restore its colour as they are stripe ones
pollandnik - Responder
so i have checkered vans and i cleaned it like that but with just water anD THE ENDS FADED how do i restore the checkers?
jenna - Responder
My shoes are leafy green what am i gonna do about it.?
Rocky Bhai - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 37
Últimos 7 dias: 247
Últimos 30 dias: 1,091
Duração total: 188,176
