Ir para o conteúdo principal
Hover-1 XLS LCD Screen Replacement
O que você precisa
  1. Hover-1 XLS LCD Screen Replacement, Ignition: passo 1, imagem 1 %32
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
    Pergunte ao FixBot
  2. Hover-1 XLS LCD Screen Replacement: passo 2, imagem 1 %32 Hover-1 XLS LCD Screen Replacement: passo 2, imagem 2 %32 Hover-1 XLS LCD Screen Replacement: passo 2, imagem 3 %32
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
    Pergunte ao FixBot
  3. Hover-1 XLS LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
    Pergunte ao FixBot
  4. Hover-1 XLS LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32 Hover-1 XLS LCD Screen Replacement, LCD Screen: passo 4, imagem 2 %32 Hover-1 XLS LCD Screen Replacement, LCD Screen: passo 4, imagem 3 %32
    • Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
    • Remove the casing on the LCD.
    Pergunte ao FixBot
  5. Hover-1 XLS LCD Screen Replacement: passo 5, imagem 1 %32 Hover-1 XLS LCD Screen Replacement: passo 5, imagem 2 %32 Hover-1 XLS LCD Screen Replacement: passo 5, imagem 3 %32
    • Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
    • Gently lift off the LCD screen.
    • Follow iFixit's soldering guide to remove the LCD screen.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S1-G2, White Winter 2019 Membro de Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 65
Ao todo: 2,038
