Ir para o conteúdo principal
Hover-1 XLS Front Wheel Replacement
O que você precisa
  1. Hover-1 XLS Front Wheel Replacement, Front Brake: passo 1, imagem 1 %32 Hover-1 XLS Front Wheel Replacement, Front Brake: passo 1, imagem 2 %32 Hover-1 XLS Front Wheel Replacement, Front Brake: passo 1, imagem 3 %32
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Front Wheel Replacement: passo 2, imagem 1 %32
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Front Wheel Replacement: passo 3, imagem 1 %32 Hover-1 XLS Front Wheel Replacement: passo 3, imagem 2 %32
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
  4. Hover-1 XLS Front Wheel Replacement, Front Wheel: passo 4, imagem 1 %32 Hover-1 XLS Front Wheel Replacement, Front Wheel: passo 4, imagem 2 %32
    • Remove the two, 16 mm Hex #4 screws on both of the hub caps in the front wheel.
    • There are two hub caps on the front wheel. Make sure to remove two screws for both hub caps.
  5. Hover-1 XLS Front Wheel Replacement: passo 5, imagem 1 %32 Hover-1 XLS Front Wheel Replacement: passo 5, imagem 2 %32
    • Using an adjustable spanner wrench, rotate the 165 mm bolt counter-clockwise to remove.
  6. Hover-1 XLS Front Wheel Replacement: passo 6, imagem 1 %32 Hover-1 XLS Front Wheel Replacement: passo 6, imagem 2 %32 Hover-1 XLS Front Wheel Replacement: passo 6, imagem 3 %32
    • After removing the first bolt, the second bolt located on the other side of the wheel will be able to be take off by hand.
    • Pull the wheel and bike in opposite directions to remove the wheel.
Conclusão
Jonathan Hidalgo
Membro desde: 01/24/19
575 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G2, White Winter 2019 Membro de Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
Membros da 3
Autoria de 6 guias
Um comentário
How do I get in touch with customer service for parts?
tried filling out the form on computer and phone as well tablet and it says error.
fox_Jayson@yahoo.com
please reach out
petrasherbin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,197
