Ir para o conteúdo principal
Hover-1 Ultra Charging Port Replacement
O que você precisa
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Hover-1 Ultra Charging Port Replacement, Charging Port: passo 1, imagem 2 %32 Hover-1 Ultra Charging Port Replacement, Charging Port: passo 1, imagem 3 %32
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Charging Port Replacement: passo 2, imagem 1 %32 Hover-1 Ultra Charging Port Replacement: passo 2, imagem 2 %32
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Hover-1 Ultra Charging Port Replacement: passo 3, imagem 1 %32 Hover-1 Ultra Charging Port Replacement: passo 3, imagem 2 %32 Hover-1 Ultra Charging Port Replacement: passo 3, imagem 3 %32
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Hover-1 Ultra Charging Port Replacement: passo 4, imagem 1 %32 Hover-1 Ultra Charging Port Replacement: passo 4, imagem 2 %32 Hover-1 Ultra Charging Port Replacement: passo 4, imagem 3 %32
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
Conclusão
To reassemble your device, follow the instructions for step 1 in reverse order.
3 outras pessoas executaram este guia.
Camron Clifton
Membro desde: 10/22/18
409 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S7-G5, Lore Fall 2018 Membro de UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 742
