Ir para o conteúdo principal
Hover-1 Titan Wheel and Motor Replacement
O que você precisa
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: passo 1, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: passo 1, imagem 2 %32
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: passo 2, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: passo 3, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 3, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 3, imagem 3 %32
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: passo 4, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: passo 4, imagem 2 %32
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: passo 5, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 5, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: passo 6, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 6, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 6, imagem 3 %32
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: passo 7, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 7, imagem 2 %32
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: passo 8, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 8, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 8, imagem 3 %32
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: passo 9, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 9, imagem 2 %32
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: passo 10, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 10, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 10, imagem 3 %32
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: passo 11, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 11, imagem 2 %32
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: passo 12, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 12, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 12, imagem 3 %32
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: passo 13, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 13, imagem 2 %32
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: passo 14, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 14, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 14, imagem 3 %32
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: passo 15, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 15, imagem 2 %32
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: passo 16, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 16, imagem 2 %32 Hover-1 Titan Wheel and Motor Replacement: passo 16, imagem 3 %32
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: passo 17, imagem 1 %32 Hover-1 Titan Wheel and Motor Replacement: passo 17, imagem 2 %32
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
Conclusão
3 outras pessoas executaram este guia.
Emma Huun
Membro desde: 10/08/18
312 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G4, White Fall 2018 Membro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Duração total: 1,797
