Ir para o conteúdo principal
Hover-1 Titan Right Gyroscope Replacement
O que você precisa
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: passo 1, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: passo 1, imagem 2 %32
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: passo 2, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: passo 3, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 3, imagem 2 %32 Hover-1 Titan Right Gyroscope Replacement: passo 3, imagem 3 %32
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: passo 4, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: passo 4, imagem 2 %32
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: passo 5, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 5, imagem 2 %32 Hover-1 Titan Right Gyroscope Replacement: passo 5, imagem 3 %32
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: passo 6, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 6, imagem 2 %32
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: passo 7, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 7, imagem 2 %32
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: passo 8, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 8, imagem 2 %32
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: passo 9, imagem 1 %32 Hover-1 Titan Right Gyroscope Replacement: passo 9, imagem 2 %32
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: passo 10, imagem 1 %32
    • Cut the cable tie and unplug the remaining wires.
Conclusão
Jessica Ouyang
Membro desde: 10/08/18
619 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G4, White Fall 2018 Membro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
Membros da 4
Autoria de 10 guias
Um comentário
Where can I get the circuit boards for the left and right ?
jfsucher - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 1,149
