Ir para o conteúdo principal
Hover-1 Titan Power Button Replacement
O que você precisa
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: passo 1, imagem 1 %32 Hover-1 Titan Power Button Replacement, Bottom Right Panel: passo 1, imagem 2 %32
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Power Button Replacement: passo 2, imagem 1 %32 Hover-1 Titan Power Button Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Power Button Replacement: passo 3, imagem 1 %32 Hover-1 Titan Power Button Replacement: passo 3, imagem 2 %32 Hover-1 Titan Power Button Replacement: passo 3, imagem 3 %32
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Power Button Replacement, Power Button: passo 4, imagem 1 %32 Hover-1 Titan Power Button Replacement, Power Button: passo 4, imagem 2 %32
    • Disconnect the battery by holding the yellow connectors and pulling apart.
  5. Hover-1 Titan Power Button Replacement: passo 5, imagem 1 %32 Hover-1 Titan Power Button Replacement: passo 5, imagem 2 %32 Hover-1 Titan Power Button Replacement: passo 5, imagem 3 %32
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
  6. Hover-1 Titan Power Button Replacement: passo 6, imagem 1 %32 Hover-1 Titan Power Button Replacement: passo 6, imagem 2 %32
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
  7. Hover-1 Titan Power Button Replacement: passo 7, imagem 1 %32 Hover-1 Titan Power Button Replacement: passo 7, imagem 2 %32 Hover-1 Titan Power Button Replacement: passo 7, imagem 3 %32
    • Pull the power button out of the panel.
    • Replace the power button.
Conclusão
Alexander Pham
Membro desde: 10/07/18
221 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G4, White Fall 2018 Membro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 559
