Ir para o conteúdo principal
Hover-1 Titan Left Gyroscope Replacement
O que você precisa
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: passo 1, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: passo 1, imagem 2 %32
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: passo 2, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: passo 3, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 3, imagem 2 %32 Hover-1 Titan Left Gyroscope Replacement: passo 3, imagem 3 %32
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: passo 4, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: passo 4, imagem 2 %32
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: passo 5, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 5, imagem 2 %32 Hover-1 Titan Left Gyroscope Replacement: passo 5, imagem 3 %32
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: passo 6, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 6, imagem 2 %32
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: passo 7, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 7, imagem 2 %32
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: passo 8, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 8, imagem 2 %32
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: passo 9, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 9, imagem 2 %32
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: passo 10, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 10, imagem 2 %32
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: passo 11, imagem 1 %32 Hover-1 Titan Left Gyroscope Replacement: passo 11, imagem 2 %32
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: passo 12, imagem 1 %32
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
Conclusão
Jessica Ouyang
Membro desde: 10/08/18
619 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G4, White Fall 2018 Membro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
Membros da 4
Autoria de 10 guias
2 comentários
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - Responder
Where do you buy the board?
eden11 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 1,061
