Ir para o conteúdo principal
Hover-1 Titan Battery Replacement
O que você precisa
  1. Hover-1 Titan Battery Replacement, Bottom Right Panel: passo 1, imagem 1 %32 Hover-1 Titan Battery Replacement, Bottom Right Panel: passo 1, imagem 2 %32
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Battery Replacement: passo 2, imagem 1 %32 Hover-1 Titan Battery Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Battery Replacement: passo 3, imagem 1 %32 Hover-1 Titan Battery Replacement: passo 3, imagem 2 %32 Hover-1 Titan Battery Replacement: passo 3, imagem 3 %32
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Battery Replacement, Battery: passo 4, imagem 1 %32 Hover-1 Titan Battery Replacement, Battery: passo 4, imagem 2 %32
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Battery Replacement: passo 5, imagem 1 %32 Hover-1 Titan Battery Replacement: passo 5, imagem 2 %32
    • Remove the bundle of wires from the clip on the top of the battery.
  6. Hover-1 Titan Battery Replacement: passo 6, imagem 1 %32 Hover-1 Titan Battery Replacement: passo 6, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
  7. Hover-1 Titan Battery Replacement: passo 7, imagem 1 %32 Hover-1 Titan Battery Replacement: passo 7, imagem 2 %32 Hover-1 Titan Battery Replacement: passo 7, imagem 3 %32
    • Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
Conclusão
Uma outra pessoa concluiu este guia.
Jessica Ouyang
Membro desde: 10/08/18
619 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G4, White Fall 2018 Membro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 34
Duração total: 2,072
