Ir para o conteúdo principal
Hover-1 Superstar Speaker Replacement
O que você precisa
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: passo 1, imagem 1 %32 Hover-1 Superstar Speaker Replacement, Bottom Case: passo 1, imagem 2 %32 Hover-1 Superstar Speaker Replacement, Bottom Case: passo 1, imagem 3 %32
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Speaker Replacement: passo 2, imagem 1 %32
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
  4. Hover-1 Superstar Speaker Replacement: passo 4, imagem 1 %32
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
  5. Hover-1 Superstar Speaker Replacement: passo 5, imagem 1 %32
    • Remove the speaker from its port.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 290
